CUCM/CUC Second NTP Server
jason.henderson
I'm looking at a client UC setup at the moment, and the NTP reference for CUCM and CUC is a lab one that is now inaccessible.  I don't want to remove and change this because I'll have to go through the licencing again.
My question is - can I add a second one and keep the licencing fine?  Version 8.6(4)SU2.
Thanks in advance,
Jason
Harmit Singh
Hi Jason,
Yes, you can add another NTP server and it will have no impact to licensing. I've tested this on UCM 8.5 in the past.
HTH.
Harmit.
Aman Soi
Hi Jason,
I remember we can add five external NTP servers in Cisco Call Manager  version 6 .x and cisco recommends at least three.
Not sure about call manager version 8
regds,
aman
Harmit Singh
Hi Jason,
HTH.
Harmit.
Just took the plunge and added a second NTP reference to CUC and it's working fine, no licencing issues.
Cheers!
