CUCM database replication failed
samhopealpha
Hi everybody,
I was trying to add a subscriber to the publisher, but fail
- when checking the database replication state, it says the replication status are OFF-LINE
- when checking the informix database, it says Password Validation for user failed
(shown as below)
Is there anything wrong in here?
DB and Replication Services: ALL RUNNING
Cluster Replication State: N/A
DB Version: ccm8_6_2_20000_2
Number of replicated tables: 0
Cluster Detailed View from PUB (2 Servers):
                                           PING                          REPLICATION          REPL.          DBver&           REPL.          REPLICATION SETUP
SERVER-NAME          IP ADDRESS            (msec)          RPC?          STATUS               QUEUE          TABLES           LOOP?          (RTMT) & details
CUCM-PUB          10.10.10.1          0.033          Yes          Off-Line          N/A              match          N/A            (0) PUB
CUCM-SUB          10.10.10.2          0.124          Yes          Off-Line          N/A              match          N/A            (0) N/A
file view activelog cm/log/informix/ccm.log
19:27:09  Password Validation for user [dbdbl] failed!
19:27:09  Check for password aging/account lock-out.
19:27:09  listener-thread: err = -952: oserr = 0: errstr = dbdbl@CUCM-SUB[CUCM-SUB]: User (dbdbl@CUCM-SUB[CUCM-SUB])'s password is not correct for the database server.
19:27:10  Password Validation for user [dblpm] failed!
19:27:10  Check for password aging/account lock-out.
19:27:10  listener-thread: err = -952: oserr = 0: errstr = dblpm@CUCM-SUB[CUCM-SUB]: User (dblpm@CUCM-SUB[CUCM-SUB])'s password is not correct for the database server.
19:27:11  Password Validation for user [dbris] failed!
19:27:11  Check for password aging/account lock-out.
19:27:11  listener-thread: err = -952: oserr = 0: errstr = dbris@CUCM-SUB[CUCM-SUB]: User (dbris@CUCM-SUB[CUCM-SUB])'s password is not correct for the database server.
19:27:12  Password Validation for user [dbauditlog] failed!
19:27:12  Check for password aging/account lock-out.
19:27:12  listener-thread: err = -952: oserr = 0: errstr = dbauditlog@CUCM-SUB[CUCM-SUB]: User (dbauditlog@CUCM-SUB[CUCM-SUB])'s password is not correct for the database server.
19:27:15  Password Validation for user [dbtvs] failed!
19:27:15  Check for password aging/account lock-out.
19:27:15  listener-thread: err = -952: oserr = 0: errstr = dbtvs@CUCM-SUB[CUCM-SUB]: User (dbtvs@CUCM-SUB[CUCM-SUB])'s password is not correct for the database server.
2 Accepted Solutions
Rob Huffman
Hi Sam,
I was looking at your previous thread with the related Sub build-out
and I believe you may be hitting this (these) bug(s);
CSCua09290 - CLI "set password user security" did not set the correct apps password
Description
Symptom:
DB Connection to Pub will fail due to incorrect database password error in ccm.log  ; Replication may
not setup
Conditions:
The defect is valid in the following two scenario:
Scenario 1:
1) Reset password on the Publisher, and reboot
2) Fresh install the Sub with the new security password
3) After the Sub completed the installation
3a) cluster manager on both pub and sub should have all servers authenticated, verify from cli (show
network cluster) ( If this is not the case, the problem is different)
3b) Local database connection is valid, to verify, execute from root (idblj -e "select * from
processnode") on both servers, data should return ( If this is not the case, the problem is different)
3c) Replication will not be setup, ccm.log on Publisher should report -952 Error code.
Scenario 2:
1) Fresh install a Publisher.
2) Run 'utils import config' to change the hostname, password and
security password.
3) Fresh install a Subscriber using the same security password set in
Step 2.
4) Once the Subscriber install is finished, the Informix logs show that
the database passwords do not match:
08:15:12 Password Validation for user [dbauditlog] failed!
08:15:12 Check for password aging/account lock-out.
08:15:12 listener-thread: err = -952: oserr = 0: errstr =
dbauditlog@nw16-vm217: User (dbauditlog@nw16-vm217)'s password is not
Additional Info:
Even with the fix for this defect, there is another issue in 8.6(2) that will cause the passwords to be out
of sync (CSCts10778).  The workaround is to run "utils os secure permissive" prior to changing the
security passphrase.
Details
First Found in:                          (1)
9.0(0.99101.22)
Status:
Fixed
Last Modified:
Jan 25,2013
Fixed in:                          (9)
9.1(1.10000.11),9.0(1.98000.42),9.0(1.98000.12)
9.0(1.11003.1),8.6(2.22900.9),8.6(2.22900.4)
8.6(2.22043.2),1.0(0.98000.42),1.0(0.98000.16)
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
CSCuc09996 : Replication fails after deploying CUCM using "New Identity process"
Symptom:
After deploying CUCM using "New Identity process"  we could see below symptoms.
++ Replication status would be "off-Line" in all the servers with in cluster.
++ admin:file view activelog /cm/log/informix/ccm.log
14:32:09  Password Validation for user [dbmon] failed!
14:32:09  Check for password aging/account lock-out.
14:32:09   listener-thread: err = -952: oserr = 0: errstr = dbmon@dc1-nssl2cm2:  User (dbmon@dc1-nssl2cm2)'s password is not correct for the database  server.
14:32:11  Password Validation for user [dbmon] failed!
14:32:11  Check for password aging/account lock-out.
14:32:11   listener-thread: err = -952: oserr = 0: errstr = dbmon@dc1-nssl2cm2:  User (dbmon@dc1-nssl2cm2)'s password is not correct for the database  server.
14:32:13  Password Validation for user [dbris] failed!
14:32:13  Check for password aging/account lock-out.
14:32:13   listener-thread: err = -952: oserr = 0: errstr = dbris@dc1-nssl2cm2:  User (dbris@dc1-nssl2cm2)'s password is not correct for the database  server.
14:32:17  Password Validation for user [dbtvs] failed!
14:32:17  Check for password aging/account lock-out.
14:32:17   listener-thread: err = -952: oserr = 0: errstr = dbtvs@dc1-nssl2cm2:  User (dbtvs@dc1-nssl2cm2)'s password is not correct for the database  server.
14:32:17  Password Validation for user [dbdbl] failed!
14:32:17   listener-thread: err = -952: oserr = 0: errstr = dbdbl@dc1-nssl2cm2:  User (dbdbl@dc1-nssl2cm2)'s password is not correct for the database  server.
Conditions:
++ Customer is using New Identity process for installing the CUCM servers.
++ He does this by copying the existing CUCM VM to a VM Template.
++  New server would be cloned using VM Template and he will import the  platformconfig.xml (generated from "Answer file generator") for changing  parameters (like IP_Address, User ID, password e.t.c.,).
++ DB replication gets failed after proceeding with above mentioned install.
Workaround:
The  workaround for the defect is to set the os security to permissive prior  to running the set password or import config commands
Cheers!
Rob
EDIT: it looks like this bug supercedes CSCuc09996
CSCts10778 - Denials thrown for security Password Recovery procedure
Description
Symptom:
Conditions:
8.6.2.10000.5
Workaround:
Set os security mode to permissive prior to changing the password.
Additional Information:
In 8.6(2), the fix for CSCua09290 is also required in order for the passwords not to get out of sync.
Details
First Found in:                          (2)
8.6(2.10000.5),8.6(2.21900.5)
Status:
Fixed
Last Modified:
Jan 25,2013
Fixed in:                          (6)
9.0(1.10000.37),9.0(1.10000.15),8.6(2.98000.7)
8.6(2.98000.16),8.6(2.23050.1),1.0(0.98000.42)
Product:
Platform:
Dependent
Severity:
3 - moderate
"Clocks go slow in a place of work
Minutes drag and the hours jerk"
-The Clash
Hey Sam,
You are most welcome my friend
That is exactly right;
So set it via cli as you nicely noted and then re-do the password.
Cheers!
Rob
-The Clash
Rob Huffman
Hi Sam,
Description
Symptom:
not setup
Conditions:
Scenario 1:
Scenario 2:
security password.
Step 2.
Additional Info:
Details
First Found in:                          (1)
9.0(0.99101.22)
Status:
Fixed
Last Modified:
Jan 25,2013
Fixed in:                          (9)
Less
Product:
Platform:
Dependent
Severity:
3 - moderate
Symptom:
Conditions:
Workaround:
Cheers!
Rob
Description
Symptom:
Conditions:
8.6.2.10000.5
Workaround:
Details
First Found in:                          (2)
Status:
Fixed
Last Modified:
Jan 25,2013
Fixed in:                          (6)
Product:
Platform:
Dependent
Severity:
3 - moderate
-The Clash
Thanks for the quick respond, but I'm not really understand about the workaround...
does it mean i have to go CUCM console, and run
but then set password ? does it mean set the security password again?
thanks
Hey Sam,
Cheers!
Rob
-The Clash
thanks for the clear instruction, i will try it on monday
