AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
2961
Beginner
CUCM dbreplication rhosts files
Hi, all.
I have a CUCM cluster 8.5 with two nodes.
In Cisco Unified Reporting - Database Status Report it's all right with replication: All server have a good replication status (2 - good).
But in section Unified CM Rhosts rhosts files do not mutch. It's happened after domain name change.
Does anybody know wheter it is a seriouse problem or not. Replication is good but that files do not mutch?
And, how can I modify Rhosts file to make them the same?
Everyone's tags (3)
6 REPLIES 6
Highlighted
Rising star
Re: CUCM dbreplication rhosts files
Do a full restart for the cluster and it will be solved.
Amer
Beginner
I restarted publisher and than subsxriber.
But files are still different.
Enthusiast
Restart(stop and start) the service 'A Cisco DB' on the servers. That should generate the file again.
Hope that helps
Nitesh
PS:Please rate helpful posts
I know it's been awhile since
I know it's been awhile since this last post but I am having the same issue on release 10 after migrating databases. Does this cause an outage of any sort?
CM
I had faced the same issue when i changed the domain on CUCM 11.5 servers. However I restarted A Cisco DB service on both(Stop and start of the service on subscriber then publisher) nodes and it's working fine now.
Thanks a lot.
Beginner
I changed the Hostname of my CUCM Nodes (Ver 10.5.2), after that i had this problem. Cisco TAC Engg restarted 'A Cisco DB' service only on the publisher node. The file got rectified.
It took 3 mins for the service restart - No impact on user facing feature observed.
The TAC Engg also shared the below reference document.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200396-Steps-to-Troubleshoot-Database-Replicati.html
Thanks.
Content for Community-Ad
August's Community Spotlight Awards
