05-02-2011 02:24 AM - edited 03-16-2019 04:45 AM
Hi, all.
I have a CUCM cluster 8.5 with two nodes.
In Cisco Unified Reporting - Database Status Report it's all right with replication: All server have a good replication status (2 - good).
But in section Unified CM Rhosts rhosts files do not mutch. It's happened after domain name change.
Does anybody know wheter it is a seriouse problem or not. Replication is good but that files do not mutch?
And, how can I modify Rhosts file to make them the same?
05-02-2011 02:27 AM
Do a full restart for the cluster and it will be solved.
Amer
05-02-2011 02:32 AM
I restarted publisher and than subsxriber.
But files are still different.
05-02-2011 01:02 PM
Restart(stop and start) the service 'A Cisco DB' on the servers. That should generate the file again.
Hope that helps
Nitesh
PS:Please rate helpful posts
12-05-2014 10:35 AM
I know it's been awhile since this last post but I am having the same issue on release 10 after migrating databases. Does this cause an outage of any sort?
CM
08-24-2016 05:30 AM
I had faced the same issue when i changed the domain on CUCM 11.5 servers. However I restarted A Cisco DB service on both(Stop and start of the service on subscriber then publisher) nodes and it's working fine now.
Thanks a lot.
01-30-2017 03:26 AM
I changed the Hostname of my CUCM Nodes (Ver 10.5.2), after that i had this problem. Cisco TAC Engg restarted 'A Cisco DB' service only on the publisher node. The file got rectified.
It took 3 mins for the service restart - No impact on user facing feature observed.
The TAC Engg also shared the below reference document.
Thanks.
