10-12-2012 07:35 AM - edited 03-16-2019 01:39 PM
Hello to ALL
actually i have a issue on my CUCM Deployment
i have two diffrent Company which have only one H323 Gateway with 8 fxo ports, my problem is hwo can i seperate this two company formincoming and outgoing company, i know if i use CUCME can use COR List but in CUCM how can i do this
8*FXO ---> 2811 (H323Gateway) -----> CUCM7.1
10-13-2012 02:56 AM
Wrong forum, post in "Voice - IP Telephony". You can move your post using the actions panel on the right.
10-13-2012 11:05 AM
thank you Paolo
10-13-2012 12:39 PM
Build separate partitions/calling search spaces/route/route lists patterns for each company and within the Route Lists/Route Group prefix a digit i.e. duplicate the offnet access code, then on GW build separate set of dial peers pointing to appropriate trunks.
HTH,
Chris
10-13-2012 01:10 PM
Dear Cheris
thanks for your reply
you know, if i use seperate partitions/CSS i can seperate the voip trffis based on company, but after the call is going to the PSTN from gateway how can i seprate the outgoing calls
i know i can use TRUNKGROUPS on my fxo for incomming calls, but how can i use this on Outgoing
Best Regards
John
10-13-2012 01:26 PM
As explained use different dial peers based on prefixed digit(s).
