CUCM Deployment
John Mayer
Hello to ALL
actually i have a issue on my CUCM Deployment
i have two diffrent Company which have only one H323 Gateway with 8 fxo ports, my problem is hwo can i seperate this two company formincoming and outgoing company, i know if i use CUCME can use COR List but in CUCM how can i do this
8*FXO ---> 2811 (H323Gateway) -----> CUCM7.1
5 Replies 5
paolo bevilacqua
Wrong forum, post in "Voice - IP Telephony". You can move your post using the actions panel on the right.
thank you Paolo
Build separate partitions/calling search spaces/route/route lists patterns for each company and within the Route Lists/Route Group prefix a digit i.e. duplicate the offnet access code, then on GW build separate set of dial peers pointing to appropriate trunks.
HTH,
Chris
Dear Cheris
thanks for your reply
you know, if i use seperate partitions/CSS i can seperate the voip trffis based on company, but after the call is going to the PSTN from gateway how can i seprate the outgoing calls
i know i can use TRUNKGROUPS on my fxo for incomming calls, but how can i use this on Outgoing
Best Regards
John
Chris Deren
As explained use different dial peers based on prefixed digit(s).
