06-30-2008 05:31 PM - edited 03-15-2019 11:38 AM
Hi All,
there are three sites with centralized design model. only one site has callmanager and the other two sites only gateways which phones in remote sites register through callmanager. I have a question as far as device pool. I need two remote site use SRST in the case of callmanager failure. so I have to create three device pool for all three sites and assign SRST reference to each device pool. But the problem is: media termination point, MOH, Transcoder are in default device pool. How can I make all of these available to all three sites whereas I have four device pools?
thanks
Alex
06-30-2008 06:08 PM
In the device pool you can select the MRGL. So you will have to create three different MRGL, one for each site, and assign them to the respective device pool.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008020f198.shtml
Hope that helps
06-30-2008 06:58 PM
or just simply use the same MRGL
javalenc
if this helps, please rate
