Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUCM Disaster Recovery
Chrysostomos_CY
Level 5
Level 5
One question
If you want to rebuilt a cucm and at the new installation you use a different security kye than the previous you got with the back up..Then its any problem with that??Or just when you try to use the restore proccess  then cucm will ask you to type the new security kye
cc
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
First you can only restore to the exact same version that the backup was taken.  So if the restore is done on 8.5 it would have to be a backup from 8.5, so it would prompt for a new security password if there is a mismatch.
7 Replies 7
TunNyuntMoe
It will prompt you for previous password
You'll be prompted for the "old security password" that was in place when the backup was taken only on CUCM 8.5(1) and later.
Hi Joe
it will prompt for the old password ONLY if teh version that i took the backup was 8.5 and later?
For example if the backup was for 6.x and the new security kye is different for the security kye that i had when the backup was placed then it will NOT ask for  the previous secutity kye right?
The backup was taken at 6.x version
so it will not prompt for the old security password
Thanks joe
Got it, correct it would not prompt for the security password on the DRS page when trying to restore it.  In your case you would need to change the security password on the server you are trying to do the restore on to match the security password of the backup file.
The version in my case is 6.x
so we are ok
thanks joe
