CUCM displays Download status as 'Upgrading' for 78xx ip phone CSCup98149
HI Community, I run in thiss issue, but BuG Search Tool schows no solution at the moment.
Have anyone heard about an Solution?
Upgrade 78xx ip phone firmware. The upgrade got completed successfully and the phone is working fine. But still the download status is showing as 'Upgrading' on CUCM.
Tried restarting Cisco RIS Data Collector, but still same.
But for other model ip phone the status is showing successful on same CUCM.
Conditions:
Tested on CUCM 9.x and 10.x
Workaround:
N/A
Further Problem Description:
Customer Visible
Save Bug
Open Support Case
Was the description about this Bug Helpful?(0)
Details
Last Modified:
Nov 21,2014
Status:
Open
Severity:
4 Minor
Product:
Cisco IP Phone 7800 Series
Support Cases: 4
HTH, please rate all useful posts and right answers.
4 REPLIES 4
The bug is still in Open
The bug is still in Open state. There is no firmware or workaround available at the moment to fix this issue.
Manish
Hi Manish, thanks a lot for
Hi Manish, thanks a lot for your effort. Have this state " Still Upgrading" some impact for the User (useability) ?
Armin
Highlighted
Hi Armin,As per the bug
Hi Armin,
As per the bug details the phone continues to work fine. So there will be no visible impact to the user.
Manish
Hello, I had contact to Cisco
Hello, I had contact to Cisco TAC. It is solve in 10.3.1. But no delivery date. I am still in contact to get timeline.
Cheers Armin
Content for Community-Ad
August's Community Spotlight Awards
