05-16-2016 12:52 PM - edited 03-17-2019 06:56 AM
Can CUCM auto hang up a call after a defined time (30 min for example)?
Thanks!
08-05-2019 09:30 AM
You can set the Maximum Call Duration Timer under the System Parameters of the cluster. However this will limit the duration of all calls, not just external calls. Default value is 720 minutes ( 6 hours ). Keep in mind that adjusting this call timer or any other call timer will also impact all users, including Executive and Senior Leadership.
08-05-2019 02:34 PM
PS Long time no talk Andrew! ;)
08-06-2019 07:15 AM
<facepalm>. I should be slapped for that horrible display of math!!
Howdy, Anthony!! Hope all is well with you these days and good to see you on here!
08-06-2019 07:34 AM
