CUCM - externally generated private key
Peter Fiers
Beginner
Beginner
in CUCM, is it possible to import an externally generated private key and a corresponding digital certificate as it is e.g. in Expressway?
Peter
Gordon Ross
Engager
Engager
No, unfortunately.
GTG
PS - Can you delete your duplicate post.
Please rate all helpful posts.
5 Replies 5
Gordon Ross
Engager
Engager
No, unfortunately.
GTG
Hi Gordon,
thanks for the information.
Peter
Greg Cording
Beginner
Beginner
not familiar with Expressway so might be off the mark here but if you are looking to upload a Certificate Authority (CA) root certificate and application certificate say for use by Phone Devices with CAPF to sign LSC X.509 this is detailed in "Cisco Unified Communications Operating System Administration Guide, Release 9.1(1)"
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cucos/9_1_1/CUCM_BK_C5D96C80_00_cucm-os-admin-guide-91/CUCM_BK_C5D96C80_00_cucm-os-admin-guide-91_chapter_0110.html#CUCM_TK_U93D2E37_00
"Cisco Unified Communications Operating System supports certificates that a third-party CA issues with PKCS#10 Certificate Signing Request (CSR)."
Hope this helps.
Greg
Hi Greg,
thanks for the hint but the key point here is to generate the private key, the public key and the CSR external to the UCM and upload the first two ones (pub key as a CA signed certificate, of course) to the UCM. To generate the CSR in the UCM and sign it externally, is not an option in our case.
Peter
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
There's actually a bug for that, which confirms what Gordon told you.
Request for support of wildcard certificate in CUCM & private key import
CSCta14114
java
if this helps, please rate
