CUCM Healthy
clark white
Explorer
Explorer
Experts
attached is the file from tool I am worried about the IO wait and memory utilization is it seem normal ?? it has been deployed by OVF template.
 please suggest the recommendation.
George Thomas
Advocate
Advocate
See if this helps you understand.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/97086-ccm6-cpu.html#systime
Please rate useful posts.
I think the OP's query is more: Is 10% I/O Wait a problem? That document just says "When I/O Wait is high" without defining what "High" is.
Personally, 10% I/O Wait isn't a huge load, IMHO. I am, however, curious why the system is sitting with 10% I/O wait when otherwise the system is idle. You may want to double check that your VMWare I/O speeds are within the requirements for CUCM virtualisation.
GTG
Please rate all helpful posts.
I agree with Gordon, 10% isnt high. I attached the link so that OP can understand what hes looking at.
Recognize Your Peers
