05-10-2018 11:16 PM - edited 03-17-2019 12:47 PM
I have a setup with CUCM 10.5(2) using a hunt group with broadcast algorithm.
I enabled queing on the hunt pilot and set the "When no hunt members answer, are logged in, or registered" option and set the destination and CSS appropriately.
My concern is about the "When no hunt members answer" portion of the settings.
Is there any way to set the No answer timer for this? From my test I see that by default it is about 60 seconds, but I cannot find a way to alter it.
Thank you
Vojtech
Solved! Go to Solution.
05-11-2018 04:36 AM
i havent got cucm in front of me, but isnt there a setting on the huntgroup, or hunt pilot that says :hunt group reversion timeout, or something along those lines?
05-11-2018 04:36 AM
05-11-2018 04:45 AM
05-11-2018 04:47 AM
thats OK mate, that is what the community is for. glad i could help you out
