CUCM IM & Presence 11.5.1.12900-25 Critical Error on Install
msubby
So I've got my CUCM 11.5.1.12900-21 installed and pretty much in a default state. Only exception is that I've added an entry for the IM & P server into the CUCM Server listing, as is required for installation of IM & P. We are installing from an ISO and not the OVA as our software was purchased through the NFR Solutions program.
Here is the error that I am seeing:
"/usr/local/cm/script/cm-dbms-install install PostInstall 11.5.1.12900-25 11.5.1.12900-25 /usr/local/cm /usr/local/cm/common/log/install/capture.txt " failed (1)
System will now halt.
When I try to output the diagnostics to a serial port (file), or when I reboot I get the option to output to a serial port, the file is always empty.
This is running on ESXi 6.0
I've tried the same routine about 3 times already, but always gets stuck in the same place.
Any hints or debugging that may be useful?
msubby
msubby
Has anyone installed CUCM IM & Presence from ISO with this version?
