07-15-2015 02:35 AM - edited 03-18-2019 11:35 AM
Hi All,
I am trying to install CUCM 10.5 in my VMWare ESXi server but it is failing with error code :
Internal error. ks_post.sh is exiting with result 1
I tried creating different VM and trying to install but same issue everytime.
Attaching the screenshot of the issue.
Thanks in advance,
Siddu
07-15-2015 04:34 AM
Did not come across this issue.
I suppose u are using BE7K or BE 6K since I can see applications pre-installed in attached snapshot.
Have u deployed the correct OVA template for CUCM-PUB?
regds,
aman
07-15-2015 06:04 AM
Which OVA template are you using?
07-15-2015 08:34 AM
Can you check the MD5 checksum of the image you are using? Sometimes this error is cause by a corrupted installation iso file.
Tere.
07-15-2015 09:24 AM
Google results show it's a hard disk size validation error, but I'm not sure how true that is. I'd have to follow Chris and ask what OVA you are using? I've never came across this issue before. You may want to redownload the ISO if you are using the right OVA.
