CUCM Installation in VM
Hari Prasad
Dear Team,
Please help to suggest me for CUCM Installation in VMware on Laptop. If my Laptop have 320 GB Hard disk with Intel i3 2nd gen and 4GB RAM is compitable. Actually i want to explore my VoIP skills set.
Hari
Please rate helpful posts
Thanks, Hari Prasad
Yes it can be easliy done by using VMWARE Workstation on your laptop and then you can install the Call Manager on top of it.
Br, Nadeem Please rate all useful post.
Manish Prasad
Level 5
Level 5
Hello Hari ,
Try searching on google you will find many videos , blogs explaining in details for VM-ware installation.
One if the site is blindhog.net.
Please rate all the helpful post.
Thanks Mnsh
hari
Thanks, Hari Prasad
Thanks Nadeem
hari
Thanks, Hari Prasad
