06-11-2016 02:37 AM - edited 03-17-2019 07:12 AM
hi all,
can we use instant message from lync federated with cucm and acess via cisco jabber client, any reference doc please refer?
regards
balaji
Solved! Go to Solution.
06-15-2016 04:12 AM
Hi Balaji,
I'd recommend you to go through Cisco Live Presentation BRKCOL-2020 "Cisco Unified Communications and Microsoft Integrations" (attached)
It goes through all the options you might want co consider in your scenario.
Leszek
06-11-2016 05:44 AM
Hi Balaji,You can use
You can use
06-15-2016 04:03 AM
Hi deepak,
currently customer is using cisco basic telephony without IM&P and MS office lync with all enterprise feature (chat,im&p).now they want to replace hardphone of cisco's platform with jabber ,so is there any way to utilize the entreprise feature of MS lync that can be accessed by jabber client other than voice call ?
06-15-2016 04:12 AM
06-15-2016 04:56 AM
Indeed it was a great doc . thanks for it
06-11-2016 01:42 PM
You'll have to explain what you're trying to do here, no idea what you mean you want to federate lync and access via Jabber.
A) CUCM only handles voice and video, not IM
B) IM&P is the part that handles IM&P
C) Yes, you can federate IM&P, you can find documentation on cisco.com by just searching: federation
06-15-2016 04:03 AM
Hi jaime,
06-13-2016 02:00 AM
I believe what you want is partitioned intradomain federation between IM&P and Lync.Do a search on the cisco site and you should find a dedicated document for it.
06-15-2016 04:04 AM
Hi batts,
