CUCM integ with Imagilce billy blue billing
SJ SJ
hi,
Can any one share any document, link or steps for integrating Imagilce Billy Blues Billing application with Cisco Call manager 10. 5
Jaime Valencia
You should probably be asking this to the vendor of the billing system.
If it uses the flat files, in CUCM all you need to do is add is as a billing server, if it uses AXL, you'll probably need some info from them to do this.
java
if this helps, please rate
