CUCM Integration with MOTOTRBO
Bhavani Sankar
Hi All,
Good evening.
We have Cisco Call Manager 8.6.x and MOTOTRBO RADIO server and mototrbo DP4000 Ex SERIES ATEX RADIO's. We are planning to integrate CUCM and MOTOTRBO so that VOIP users can communicate with RADIO devices. I found that this supports SIP integration. Can someone help me out in sharing the integration document?
Thanks in Advance.
Sankar.
7 Replies 7
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/bccm-861-cm/b09sip3p.html
java
if this helps, please rate
Hi Valencia,
Thank you for your input.I understand that we need to add non cisco phone that support SIP as "Third Party SIP advanced." But we are using MOTOTRBO RADIO server for  mototrbo DP4000 Ex SERIES ATEX RADIO's. So how do we integrate call manager with MOTOTRBO RADIO server.
Sankar.
If MOTOTRBO supports sip then create a SIP trunk in CUCM with its IP pointing to MOTOTRBO server. You can find many documents on how to create SIP trunk in CUCM. If you face call failure issue after setting up the trunk collect CUCM traces we will help you in narrowing down the issue.
are you able to configure it.......
Faisal
I need assistance in configuring the same..
were you able to configure it please share your experience.
@Bhavani Sankar wrote:
Hi Valencia,
Sankar.
did you achieve this integration?
I am investigating about this.
