02-11-2014 03:20 AM - edited 03-16-2019 09:41 PM
Hello everybody,
I have a phone with the firmware: SCCP45.9-0-2SR1S.loads
Added it to CUCM v8.0.2 and CUCM loaded a new firmware to the phone, but
/Device/Device Settings/Device Default
Cisco 7965 SCP SCCP45.9-0-sSR1S Def. Standard 7965 SCCP
Why it is loading the same version of the firmware?
How to stop reload the phone?
Thank you in advance.
Solved! Go to Solution.
02-11-2014 03:45 AM
Hi.
Did you restart the tftp service?
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
02-11-2014 03:45 AM
what was the Firmware load before you have uploaded the new firmware load?
02-11-2014 03:45 AM
Hi.
Let me know
Carlo
02-11-2014 06:04 AM
In addition to what has asked by friends, how many servers do you have in a cluster? Have u uploaded new firmware to all servers in a cluster and restarted tftp service?
regds,
aman
02-11-2014 11:17 AM
You need to make sure the firmware name defined in the device default phone page of CUCM matches the actual firmware name less the period before "loads" and anything to the right of the period. The first thread shows an inconssitancy between the firmware name and the listing in the device defaults..
Cisco 7965 SCP SCCP45.9-0-sSR1S Def. Standard 7965 SCCP (lower case "s" should be a number 2)
02-12-2014 08:40 AM
Hello everyone,
sorry for delay, I can't reply early...
thank you very much for you messages. I have restarted TFTP-server and everything is working properly. Anyway after your replies I know better what to check in such situation. Thanks a lot!
Dmitry
