CUCM LADP Sync / EM impact
BSILA OMAR
we are planning to use LDAP sync for the CUCM directory and according to documentation users that already exists in CUCM with the same UserID ON CUCM and LDAP will be kept. my is is whether User information that are not synchronized will be also kept? for example Extension Mobility, Mobility, Device association...
Omar
If the user matches an ID on LDAP only the user info will be updated, anything related to CUCM (pin, device/line association, etc) will be kept and won't be changed.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
DaveX4285_2
No. User ID's that arent matched are marked inactive and will be purged during the next clean up interval. The following thread outlines the process quite well.
https://supportforums.cisco.com/message/3304380#3304380
java
java
I was talking about users that match on LDAP and CUCM.
Thank java you for your response that was helpful.
Omar
