CUCM - LDAP Integration (2 different AD)
Daniel Gomez
Company A just bought Company B and both of them have a CUCM integrated with their own AD.
In order to "simplify" the administration, Company A wants users of Company B to be registered on CUCM A so there is only 1 CUCM for all of the users.
CUCM A has full AD integration with AD-A. It seems we could add AD-B so users from that directory are imported to CUCM A.
Questions:
1. Integrating AD-B on CUCM-A would allow those users to authenticate? It seems I can only have 1 authentication for the entire cluster and it is configured with AD-A.
2. Is there any way I can specify users from former CUCM-B to just see users from AD-B on their phone directories? Even if it is the same company now, customer wants to keep users separated for now.
I really appreciate any suggestions and comments.
Jaime Valencia
You would need ADAM/LDS
How to Configure Unified Communications Manager Directory Integration in a Multi-Forest Environment
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_configuration_example09186a0080b2b103.shtml
No, once you sync both domains, all the users will show up in the built-in corporate directory, you would need to write down your custom directory scripts and have it look at each LDAP server independently.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks a lot Java.
ADAM/LDS would be a Microsoft service right? It would integrate different LDAPs together so applications such as CUCM points to this LDS?
I really appreciate your help as always!!
Yes, ADAM/LDS is all MS, it will aggregate info from different domains/forests via trust relationships and have all of them accessible via a single point
java
java
