12-03-2020 02:33 PM
We have CUCM v12.5. I know that by default CUCM is not involved in a call after the call has been set up. My question: is there a way to configure media paths (RTP audio) the same as signaling paths, I mean the media exchange doesn't occur directly between the IP Phones but through the CUCM.
Thank you in advance
Sofiane
Solved! Go to Solution.
12-03-2020 02:57 PM
Yes, but you would need to use TRPs/MTPs and that doesn't scale with CUCM, you would need external resources on an ISR.
12-03-2020 02:57 PM
12-04-2020 01:03 AM - edited 12-04-2020 12:24 PM
Hello Jaime,
Thank you a lot for assisting me !
This page gives the details :
Best Regards,
Sofiane
