configure & troubleshoot anyconnect
1899
Beginner
cucm media resources allocation error
Greetings!
Does anyone know when happens situation described below?
Part of trace log:
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::waiting_AllocateMtpResourceReq - (capCount,region),A(8,Moscow),B(13,Moscow), reqDevCap=0x12, supDevCap=0x119, passthru=0, resourceCount=1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::waiting_AllocateMtpResourceReq - (not an error) DeviceCap Mismatch|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Error><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- DeviceName=C2821-SIP-A12 Ci=124092313 ResourceCount=1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- Logging RegionA=Moscow Caps and MTP/XCoder Region=Moscow Caps|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::logCapabilitiesinTrace -- MTP/XCoder Device Caps = 4 258 257 259 261 |<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::logCapabilitiesinTrace -- Device Caps = 4 2 86 15 16 11 12 257 |<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|RegionsServer::MatchCapabilities -- kbps=64, capACount=8, capBCount=5|<CLID::StandAloneCluster><NID::CUCMS-3><LVL::Detailed><MASK::0800>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- Logging RegionB=Moscow Caps and MTP/XCoder Region=Moscow Caps|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::logCapabilitiesinTrace -- Device Caps = 4 2 10 15 11 12 9 9 9 9 84 83 82 |<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|RegionsServer::MatchCapabilities -- kbps=64, capACount=13, capBCount=5|<CLID::StandAloneCluster><NID::CUCMS-3><LVL::Detailed><MASK::0800>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- match1=1 match2=1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- DeviceName=C2821-SIP-A12 Ci=124092313 ResourceAllocated=1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::getResourcesAllocated -- allocateErrBitset=0x1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Detailed><MASK::0080>
10/09/2013 11:53:05.409 CCM|MediaTerminationPointControl(41)::SendMTPResourceErrToSender - ERROR  AllocateMtpResourceReq failed -- Ci=124092313, errBitset=0x1|<CLID::StandAloneCluster><NID::CUCMS-3><CT::7,100,135,1.1562698><IP::172.16.55.239><DEV::><LVL::Error><MASK::0080>
Thanks in advance for your answers.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Beginner
Hi what configuration change
what configuration change was made to resolve the issue. Could you elaborate, i think I ran into similar issue still waiting for a fix
Chandramauli
14 REPLIES 14
Beginner
With this limited traces it would be difficult to be 100% accurate on what is causing this issue. Will need more details about the call flow and addtional logs. Though from the above, it seems to be that CallManager is trying to allocate a transcoder and the same is failing due to capabilities mismatch. This is a codec mismatch issue where you need a transcoder to be inserted and the same fails as there is none available.
Beginner
Transcoder is available, as well as MTP. I watched OutOfResources counter. It's equal to 0. Available resources counter is differ from 0 at all MTPs and Transcoder. Any other suggestions ?
Beginner
Have you checked and confirmed the devices being used here can invoke the transcoder ? Is it configured on the MGR/MGRL and assigned to the Device Pool ?
Also, can you please share the call flow and details traces. Without knowing clear call flow, it is difficult to say what is causing the issue.
Beginner
Yes, i've checked. It doesn't depend (IMO) of  any specific Device Pool or MRGL.I changed both of them. Trace stay the same. Moreover, there are few MTPs and transcoder, which aren't assigned to any MRG. Thay have to be available to all.
Call flow is :
Calling phone - CME - GK - CUCM - ICM (script strat)- IVR (greeting) - ICM (queue to skill group) - Called phone
Problem appear after called phone answer a call. If exclude step with ICM script everything works well.
VIP Mentor
From the trace we can see that the MTP device selected is =C2821-SIP-A12.  W can also see that the region between the end points and this device is set to use 64Kbps..The question is what is the codec configured for this MTP? Can you send a sh run of your gateway?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Highlighted
Beginner
From trace we can see announced list of codecs, but it's not clear: C2821-SIP-A12 is a side A or side B. And what is the difference between MTP/XCoder Device Caps and Device Caps. I mean, which one belong to selected device and whom belong the other one. Also there is a two pairs of MTP/XCoder Device Caps and Device Caps...
VIP Mentor
C2821-SIP-A12 is not side A or B, it is the chosen MTP resource. Side A or Side B are the endpoints that will be using the MTP device
gateway/Ip Phone(side A)---MTP-----IP Phone/gateway(side B)
MTP/xcoder device caps are usually the codecs or capabilites the MTP device cab support. Device caps are the codecs the devices invoking MTP can support...
Which codec do you have configured on your MTP?
Beginner
Thanks for explanations! g711u configured on MTP.
VIP Mentor
Ok..Can you send the full CUCM trace...including calling can called number
Beginner
Re: cucm media resources allocation error
Sorry for delayed answer.
Full logs of call attached. Call from 072599 to 7899 and final destination is 4555.
Beginner
Problem is solved. The cause was in interoperation between transcoder and ivr. When script on ivr plays nothing appear problem described higher.
Beginner
Chandramauli
VIP Mentor
I suggest you open a new
I suggest you open a new thread and we can look at the issue you are facing. Please describe in detail the issue you are facing and include cucm logs
Check for mtp resources on VG
Check for mtp resources on VG which Codec is configured.if your call which is not connecting to the conf call requires g729 then transoder is required.
