I have a CUCM: 8.6.2.20000-2, with a 2901 MGCP gateway Version 15.1(4)M4, RELEASE SOFTWARE (fc1).
Everytime i restart the GW all the cptone configs i made a resetted to default for ex:
voice-port 0/2/1
supervisory disconnect dualtone mid-call
input gain 3
output attenuation -1
echo-cancel coverage 32
cptone KW
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 2
timeouts wait-release 2
timing hookflash-out 50
After the restart it becomes
voice-port 0/2/1
input gain 3
timeouts initial 5
As we can see the cptone is lost.
Is there a solution to it ? or a way that i can configure the cptone from the CUCM to be KW.
Best regards.
Solved! Go to Solution.
Marc,
On the MGCP endpoint configuration is the 'Network Locale' set to 'Kuwait'
Hope this helps,
Craig
(PLEASE RATE HELPFUL POSTS)
Marc,
Hope this helps,
Craig
