CUCM NODES- ITL ERROR ALL THE SUBSCRIBERS EXCEPT PBLISHER NODE
Hi All,
we upgraded the cucm Publisher from 9.x to 12.5x, added tftp and Subscribers nodes fres install.
phones are registered in to new 12.5. but ITL files not getting installed. but if give the tftp option1 as Publisher the ITL is getting installed. all the sub nodes when i run the command show itl is getting as below,
Showing Regular ITL File.
Length of ITL file: 0
The ITL File was last modified on Wed Apr 10 16:45:35 AST 2019
        Parse ITL File
Invalid ITL file. Error skipping past version.
Error parsing the ITL File.
i am facing an same issue which specified below link. i tried with the work around as same but ia m getting the below error.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj72951/?rfs=iqvred
once i run this getting the error below,
Locating active tftp servres
tftp servers listed successfully and after
The recovery ITL file could not be written to the disk
Execute command unsuccessfully
MAC verified OK
writing RSA key
Kindly advise .
Ashiq.
tgaur
hi,
open a TAC case as this may require a root to check the ITL and keys.
regards.
Thanks Mr.tagur.
opened a case with TAC and working on it. will keep posted once its resolved.
Hi, do you have a solution? We faced the same problem at one of our client too.
HI ,
I opened a case with TAC and resolved by correcting the DB from root.
Thanks.
Ashiq
