Walkthrough Wednesdays
478
Michael Durham
Enthusiast
CUCM not updating gateway router
I am just starting to learn CUCM and following the new Cisco CCNA Voice Lab Manual.  When I go into CUCM 8.6-> Device -< Gateway - > 2851 Router -> FXO 0/3/1 and I set Rings to 6, click save and then apply, the answer rings never change to 6.  It still says 2.  Also, when I change the
My router is a 2851 with 2 FXO ports. Port 0/3/0 is shutdown because I only have one telco line.  Here is the info from my router:
voice-port 0/3/1
ring number 2
timing hookflash-out 50
timing guard-out 1000
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.110.0.5
ccm-manager config
mgcp
mgcp call-agent 10.110.0.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
The route DOES show registered in CUCM and all IP's are correct.  I can make and receive calls to the PSTN from my IP phones.
Any idea why when i apply the above config from CUCM to my 2851 nothing changes?
1 ACCEPTED SOLUTION
immudel
Beginner
I think you need to add folloing command
mgcp bind control source-interface fastethernet XX
mgcp bind media source-interface fastethernet XX
Rgds
Amim
Note: rate if you find useful
4 REPLIES 4
immudel
Beginner
Rgds
Amim
Works, kind of.  When I do the mgcp bind control source-interface gii0/1.110 it makes the changes right away.  However, when I make another change in CUCM, it does not take until I run that command again.
Hi Michael
Once you have applied the changes , do you issue a reset command from the CUCM ?
Aditya Gupta
Well... that was not in the lab manual but it WORKS!!!! Thanks.  You would think that when you apply the change via CUCM it would do the reset if required.  Come on Cisco... get it together!
Thanks for your help.
----Michael
Content for Community-Ad
Spotlight Awards 2021
