12-20-2012 07:02 AM - edited 03-16-2019 02:49 PM
I am trying to install CUCM in Vmware.when installing server , the following errors occur.
1.It doesnt identify the gateway
2.It doesnt have access to NTP server
PC Network Ip address 10.1.3.10
gateway 10.1.3.1
CUCM address 10.1.3.100
NTP Server 10.1.3.1
when i ping the gateway from pc cmd,can able to ping
NTP server also accessible(Already there is a server(CUCM) running on the same PC.This cucm has access to ntp server and this cucm can able to ping the gateway aswell)
kavi
Solved! Go to Solution.
12-22-2012 04:49 AM
Hey,
what is the network adapter setting for the CUCM which working properly, do u want both the CUCM on the same network, then use the same config as the one working.
cheers,
shaggy
12-20-2012 07:28 AM
What is the network/adapter setting on your vmware? Are you using bridged or private host? If you are using private host, have you configured your host adaptern network to be in the same ip range as your vmware cucm server?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
12-20-2012 07:35 AM
hi aokanlawon,
I dont understand the vmware setting (briged or private).could you explain.
thanks
12-21-2012 01:16 AM
Could some one help me with this
thanks
12-21-2012 01:24 AM
Hi Kavithas
Where did you try to install the CUCM.wHERE IS LOCATED THE VM
Also did you use the ova file from vm from cisco?
12-21-2012 04:34 AM
The VM is located on the pc itself.
12-21-2012 01:27 AM
What type of vmware are you using. I assumed you are using vmware workstation or vmware player..
12-21-2012 04:30 AM
HI
I am using VMware workstation
12-21-2012 04:42 AM
So have you configured the VMware settings? On one of the TABS you should virtual machine settings. Scroll to Network adapter, select host only. Then go your pc and in your network adapter section, look for the vmware network adapter vmnet1. Assign an ip address in the same network as your cucm server. If you want you can make this your gateway
12-21-2012 06:43 PM
There is a cucm running already on the vmware.For that i set the vmware setting(vmware network adapter0 is mapped to pc newrk adapter).It is been working.now I am trying to install another server on the same vmware workstation.I am having problem here.what setting should I do for this?
12-22-2012 04:49 AM
Hey,
cheers,
shaggy
12-22-2012 03:46 PM
First thing I'd ask is did you install the OVA?
12-22-2012 09:43 PM
Hello Kavithas,
What is your version of VMWare Workstation?
This is a screenshoot for VMWare version 7 and it works well.
If it is useful please rate.
Best regards.
