CUCM on Vmware
tkavithas87
Beginner
Beginner
I am trying to install CUCM in Vmware.when installing server , the following  errors occur.
1.It doesnt identify the gateway
2.It doesnt have access to NTP server
PC Network  Ip address 10.1.3.10
gateway 10.1.3.1
CUCM address 10.1.3.100
NTP Server 10.1.3.1
when i ping the gateway from pc cmd,can able to ping
NTP server also accessible(Already there is a server(CUCM) running on the same PC.This cucm has access to ntp server and this cucm can able to ping the gateway aswell)
kavi
Hey,
          what is the network adapter setting for the CUCM which working properly,  do u want both the CUCM on the same network, then use the same config as the one working.
cheers,
shaggy
12 Replies 12
What is the network/adapter setting on your vmware? Are you using bridged or private host? If you are using private host, have you configured your host adaptern network to be in the same ip range as your vmware cucm server?
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
hi aokanlawon,
I dont understand the vmware setting (briged or private).could you explain.
thanks
Could some one help me with this
thanks
Hi Kavithas
Where did you try to install the CUCM.wHERE IS LOCATED THE VM
Also did you use the ova file from vm from cisco?
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
The VM is located on the pc itself.
What type of vmware are you using. I assumed you are using vmware workstation or vmware player..
HI
I am using VMware workstation
So have you configured the VMware settings? On one of the TABS you should virtual machine settings. Scroll to Network adapter, select host only. Then go your pc and in your network adapter section, look for the vmware network adapter vmnet1. Assign an ip address in the same network as your cucm server. If you want you can make this your gateway
There is a cucm running already on the vmware.For that i set the vmware setting(vmware network adapter0 is mapped to pc newrk adapter).It is been working.now I am trying to install another server on the same vmware workstation.I am having problem here.what setting should I do for this?
Hey,
cheers,
shaggy
kevinmpotts
Beginner
Beginner
First thing I'd ask is did you install the OVA?
Emmanuel Valdez
Participant
Participant
Hello Kavithas,
What is your version of VMWare Workstation?
This is a screenshoot for VMWare version 7 and it works well.
If it is useful please rate.
Best regards.
Recognize Your Peers
