CUCM "DIAL-PEERS"
isaaco001
Beginner
Beginner
Hi everyone,
I am familiar with CME and would like to understand the equivalent of dial-peers in CUCM. I trying to connect a CME to a CUCM through their dial-peers. where are dial-peers configured in CUCM?Am new to CUCM and guides or links to this issue will be appreciated.
Thanks!
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
George Sotiropoulos
Hello Isaac,
You may read the following document for interconnection of CUCM with CME:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-voice/922-cisco-voice-cucm-cme-h323.html
Generally speaking, you will need to create connetivity (H323 or SIP trunk) between the 2 systems and then create route-patterns, which are the equivalent of the dial-peers on the CME.
You will find various posts at Community concerning this subject.
Hope this helps,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
Jaime Valencia
You want to do some reading on this:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/dialplan.html
java
if this helps, please rate
Recognize Your Peers
