Highlighted
Explorer
CUCM Region Mapping
Hello everyone,
In CUCM 11.x is there a way to avoid having to map each new region manually to all the other existing regions when a new region is created?
All replies rated
Thanks in advance
1 ACCEPTED SOLUTION
Hall of Fame Master
Correct, you simply relay on
Correct, you simply relay on following CUCM service parameters:
Default Intraregion Max Audio Bit Rate
Default Interregion Max Audio Bit Rate
Default Intraregion Max Video Call Bit Rate (Includes Audio)
Default Interregion Max Video Call Bit Rate (Includes Audio)
Default Intraregion Max Immersive Video Call Bit Rate (Includes Audio)
Default Interregion Max Immersive Video Call Bit Rate (Includes Audio)
1 REPLY 1
Hall of Fame Master
Content for Community-Ad
July's Community Spotlight Awards
