cucm reports
mkhriesa
hi
cucm 11.5
Please to connect remotely with me, I need to extracted a report for admin access to the call managers in the past two months.
Is there any such report?
Jaime Valencia
No, you'd need to review the Role-based security traces
java
if this helps, please rate
Hi Jaim
do you mean there is a specific logs for it? and easy to trace the last 2 month?
You'll have to review the logs to find out how far they go, that will depend on your environment and the amount of changes done.
java
