cucm reports
mkhriesa
Beginner
Beginner
hi
cucm 11.5
Please to connect remotely with me, I need to extracted a report for admin access to the call managers in the past two months.
Is there any such report?
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
No, you'd need to review the Role-based security traces
java
if this helps, please rate
Hi Jaim
do you mean there is a specific logs for it? and easy to trace the last 2 month?
Jaime Valencia
You'll have to review the logs to find out how far they go, that will depend on your environment and the amount of changes done.
java
Recognize Your Peers
