01-30-2018 07:01 PM - edited 03-17-2019 12:04 PM
Hi all, my current system got many route partition and some indicated _local, _international..etc. My question is how do i know that particular partition is going internal only? How to check it is really internal ext call only?
01-30-2018 07:06 PM
01-30-2018 07:19 PM
The only way to find that out, is by reviewing everything in your dial plan which has that partition configured, only then you'd be able to tell if the internal partition only has internal DNs or not. Same for any other partition.
01-30-2018 07:30 PM
01-30-2018 08:11 PM
