188
Highlighted
Beginner
CUCM Route patterns for NL
I need to configure cucm route patterns for Netherlands PSTN that is not my country. Can someone please share some route patterns that usually use for this country.
MC
1 REPLY 1
Highlighted
VIP Rising star
Cisco have a numbering plan for Netherlands.  Alongside the readme you can also download the flat pattern file.
 https://software.cisco.com/download/home/278719042/type/282074292/os/Linux/release/3-1-7-NL
Together with the digit discard options, this should give a good idea even if you're going to create your own manual dial plan.
For what it's worth I always check a few sources for country numbering plans, including checking with the customer for any other patterns they're used to dialling.  Cisco NPs are not always correct or up to date.
Content for Community-Ad
