Hi All
I am using CM 12.5 self care portal. In the portal there is a download tab as shown in the picture
I would like to add Jabber and some plugins to that tab. Is that possible?
If its possible, how do we achieve this ?
Kind regards
Pragash
Solved! Go to Solution.
No, you cannot, only the built-in options can be there.
Thanks Jaime for your response.
You can able to do following tasks in self care portal. The below guide is for call manager version 12.X, you can check other versions also. By going selecting your exact version for which you are looking for.
