03-17-2016 01:03 AM - edited 03-17-2019 06:17 AM
we have solarwinds installed that is receiving a rejected phones warning from cucm , the issue is there is no details of the phone that is giving this warning , my colleague told me it might be a warning from un-configured phone in cucm connected to our network , but the thing is i cant trace it? is there anywhere in cucm that shows phone that tried to connect and got rejected?
03-17-2016 01:41 AM
You'll have to scan the CUCM trace logs for this.
Either download them with RTMT or search them like so:
file search activelog cm/trace/ xxxx recurs ignorecase reltime minutes 30
-- this will search the last 30 minutes worth of logs for the phrase xxx - Do this when the alert triggers and replace xxx with a suitable phrase or word such as rejected or a phrase from the alert you receive until you find it.
Aaron
03-17-2016 03:08 AM
i did that and i received the following message
/var/log/active/cm/trace/ccm/sdl/SDL005_100_000626.txt.gz:17092445.154 : AppInfo :DMMSStationD-SD(1261) - removeDialogSubscriptions: subscription rejected
please can anyone explain what does it mean? how can i solve it?
