03-10-2015 08:20 AM - edited 03-17-2019 02:16 AM
Hello
This may be a simple question but I've been asked to investigate it.
We have a CUCM version 9.1.1.10000-11 set up comprising :-
1 x Publisher
2 x Subscribers
1 x TFTP server
2 x Unity servers
2 x Presence servers
They are all currently located in two racks in a comms room in our Frankfurt office.
Is it possible to move half of them to another location to give us a redundancy scenario? Or do they need to be in the same place for some reason?
If they can be moved is it just a case of making sure the IP addresses are valid in each location or that the config is re-done to reflect the new IP addresses of the moved servers?
Solved! Go to Solution.
03-10-2015 08:24 AM
Yes, review the guidelines for CoW in the SRND for the CUCM server and the CUC HA design guide to consider the BW and RTT between sites that is required to split them over a WAN.
03-10-2015 08:24 AM
03-10-2015 08:40 AM
That looks like what I need
Thanks Jaime
