Walkthrough Wednesdays
112
Mark Boiston
Beginner
CUCM servers in different locations - possible?
Hello
This may be a simple question but I've been asked to investigate it.
We have a CUCM version 9.1.1.10000-11 set up comprising :-
1 x Publisher
2 x Subscribers
1 x TFTP server
2 x Unity servers
2 x Presence servers
They are all currently located in two racks in a comms room in our Frankfurt office.
Is it possible to move half of them to another location to give us a redundancy scenario? Or do they need to be in the same place for some reason?
If they can be moved is it just a case of making sure the IP addresses are valid in each location or that the config is re-done to reflect the new IP addresses of the moved servers?
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Yes, review the guidelines for CoW in the SRND for the CUCM server and the CUC HA design guide to consider the BW and RTT between sites that is required to split them over a WAN.
java
if this helps, please rate
2 REPLIES 2
Jaime Valencia
java
That looks like what I need
Thanks Jaime
Content for Community-Ad
Spotlight Awards 2021
