CUCM show gateway MGCP Device is not trusted
Hi, I wonder if you can help me.
I have a CUCM 9 and a gateway 2811 configured with MGCP.
The gateway is registered but on CUCM show "device is not trusted".
On the gateway I can see it's registered:
#show ccm-manager
MGCP Domain Name: ceiia_voice_gateway.ceiia.com
Priority        Status                   Host
Primary         Registered               192.168.11.200
First Backup    None
Second Backup   None
Current active Call Manager:    192.168.11.200
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            18:38:18 UTC Mar 25 2013 (elapsed time: 00:00:11)
Last MGCP traffic time:         18:38:18 UTC Mar 25 2013 (elapsed time: 00:00:11)
Last failover time:             None
Last switchback time:           None
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  192.168.11.200
    Current Link State: OPEN
    Statistics:
        Packets recvd:   0
        Recv failures:   0
        Packets xmitted: 0
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 3, port 0
FAX mode: cisco
Configuration Error History:
On show mgcp I have:
#show mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 192.168.11.200 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay voip codec all mode out-of-band
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough disabled
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
ccm-manager mgcp
ccm-manager config server 192.168.11.200
mgcp
mgcp call-agent 192.168.11.200 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp package-capability rtp-package
mgcp default-package line-package
mgcp sdp simple
mgcp bind control source-interface FastEthernet0/0
mgcp bind media source-interface FastEthernet0/0
#show mgcp
An the endpoin is, also registered.
The mgcp configuration is like this:
ccm-manager mgcp
mgcp
mgcp sdp simple
Shouldnt the CUCM say that the device is trusted since this is an MGCP connection?
I would appreciate if you can help me!!!!
Best Regards,
Jose Carlos
islam.kamal
Level 10
Level 10
Dear
you do not have any problems in your configuration, to learn more for trust which is based on certificate trust list please check the below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713.pdf.
please rate if this will help
does this alert affect incoming calls?
Thanks guys, I would dig into this to get a trusted device icon.
Best Regards,
Jose Carlos Silva
