CUCM - SIP Gateway - SIP ITSP
maryphills
Dear Friends,
I am having hard time  as my company decided to configure their new site using SIP. I am completely new to SIP and require good support.
My senario:
Cucm 6.3 ----->  H.323 gateway(2821 with CUBE supported) ----> SIP service provider
Service provider will terminate their link on to our data T1 or to ethernet port.
Can anyone helpme with the configuration at the callmanager and gateway side.
Mary Phills
2 Accepted Solutions
acampbell
Mary,
A good place to start would be the Cisco interoperability portal
http://www.cisco.com/en/US/partner/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805bd13d.html
Look through the example titles for something sinilar to your setup
You probably wont find an exact match but the basics will be the same.
E.g. you may need to use a CUCM 7 doc although you are on CUCM 6.
Example
CUCM 6.1.5 -- SIP -- CUBE--- SIP---TELUS
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns833/1035150.pdf
Also you mention your gateway/cube is existing as H323.
May be b.etter to change to CUCM----SIP TRUNK ---CUBE---SIP---SIP PROVIDER
(Less protocols)
Alex
Regards, Alex. Please rate useful posts.
Mary,
Yes leave the phones as SCCP (Skinny)
Just convert the H323 gateway to SIP working on both the router and the CUCM
This will reduce the protocols that you need on your setup.
This info is usually in the links I provided.
Alex
acampbell
Mary,
Example
(Less protocols)
Alex
Thankyou so much Alex,
So you recomment to make my gateway cofigured as SIP and do rest of the config. Can the phones be configured as
sccp
-Mary
Mary,
Alex
