05-23-2014 06:54 AM - edited 03-16-2019 10:52 PM
I'm trying to add a SIP Trunk to an provider that requires authentication. This trunk will not use a CUBE between the CUCM and the provider SIP Proxy, but the call doesnt work.
The Authentication fails and the call dies.
I'm using a CIsco CUCM version 8.6.2.20000-2 and I've configured the trunk as Follows:
- The Trunk is pointing to the SIP Proxy IP, with call classification OnNet;
- A SIP Trunk Secure Profile was created with Device Secure Mode "Authenticated" and Digest Authentication Enabled;
- I've created a SIP Realm with the Digest Credentials provided by the SIP provider.
When I try to make a call, the response is an reorder / busy tone.
05/22/2014 09:53:45.560 |//SIP/SIPUdp/wait_SdlSPISignal: Outgoing SIP UDP message to 201.71.239.194:[5060]:
[9499,NET]
INVITE sip:40107313@201.71.239.194:5060 SIP/2.0
Via: SIP/2.0/UDP 10.20.0.8:5060;branch=z9hG4bK6161d76209
From: "Wilson Lima Junior" <sip:8335@10.20.0.8>;tag=3133~a13e2bd5-d832-407a-a7d3-a57d9e5dead6-31864205
To: <sip:40107313@201.71.239.194>
Date: Thu, 22 May 2014 12:53:45 GMT
Call-ID: 1ab11800-37d1f359-4b-800140a@10.20.0.8
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 0447813632-0000065536-0000000001-0134222858
Session-Expires: 1800
P-Asserted-Identity: "Wilson Lima Junior" <sip:8335@10.20.0.8>
Remote-Party-ID: "Wilson Lima Junior" <sip:8335@10.20.0.8>;party=calling;screen=yes;privacy=off
Contact: <sip:8335@10.20.0.8:5060>
Max-Forwards: 70
Content-Length: 0
Source Filename: ccm00000244.txt.gz
Server: VSC
Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, PRACK, REFER, REGISTER
Call-Id: 1ab11800-37d1f359-4b-800140a@10.20.0.8
Max-Forwards: 70
Expires: 180
Content-Length: 0
date: Thu, 22 May 2014 12:53:45 GMT
supported: timer,resource-priority,replaces
min-se: 1800
allow-events: presence
supported: X-cisco-srtp-fallback
supported: Geolocation
cisco-guid: 0447813632-0000065536-0000000001-0134222858
session-expires: 1800
p-asserted-identity: "Wilson Lima Junior" <sip:8335@10.20.0.8:5060>
remote-party-id: "Wilson Lima Junior" <sip:8335@10.20.0.8:5060>;party=calling;screen=yes;privacy=off
Solved! Go to Solution.
05-23-2014 09:50 PM
Here is your answer.
https://supportforums.cisco.com/discussion/11835001/sip-trunk-isp-authentication-using-cisco-call-manager
Manish
05-23-2014 09:50 PM
Manish
