09-11-2022 05:14 AM
If I have a CUCM connected to a smart license and want to migrate this CUCM to another UCS, Can I easily connect the new CUCM to a smart account, or should I buy a license to migrate?
Solved! Go to Solution.
09-11-2022 08:17 AM - edited 09-11-2022 10:15 AM
If you want to move your CM to a new UCS you would not need to do anything with licensing. Just move the VMs from old ESXi host to the new that you create on the new UCS hardware.
09-11-2022 09:11 AM
Faisal,
When you migrate your CUCM to a new host using any method like vMotion, PCD or rebuild/restore, all your old CUCM configs are transferred to the new CUCM, including smart license registration settings.
Therefore, your new CUCM will automatically connect to your Smart Account/Virtual account where the CUCM licenses reside and access these licenses the same way your old CUCM did.
09-11-2022 09:11 AM
Faisal,
