Community Helping Community
1017
Beginner
CUCM SMTP server setttings
Is there anyway you can change the smtp port you are sending smtp mails on. Security is asking to us a differnt port than default 25!
kind regards
Niels
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
No, that's not something you can change.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY 1
java
java
Content for Community-Ad
FusionCharts will render here
