05-11-2012 06:52 AM - edited 03-16-2019 11:06 AM
All,
Are the individual phone registration status stored anywhere in the CUCM DB that can be queried via SQL? If so, can someone share which table and value?
I know there are multiple alternate ways of getting this information, but I am working on some custom SQL queries for CUCM that I would like to add device registration status to.
Rob
Solved! Go to Solution.
05-11-2012 10:41 AM
Depending on how you are accessing the SQL query (CLI, AXL, Other) you could run the following command on the CLI (per server):
show risdb query phone
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
05-11-2012 07:08 AM
No, that information is not stored in any table in the DB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-11-2012 08:09 AM
This information is only available via the RIS API set. It's not stored in the SQL database.
GTG
05-11-2012 10:41 AM
Anthony Holloway
03-13-2013 03:13 AM
is it possible to get with this report "show risdb query phone
" also these informations?
- directory number
- partition
- pickup group
BR
Michael
03-13-2013 06:40 AM
No, because that command gets the info only from risdb process, not from any table from CUCM.
java
03-13-2013 06:43 AM
OK thanks.
Is there any other SQL command to use to get these informations:
- all directory numbers
- partition
- description
- Associated Devices (phone or device profile)
- Call Pickup Group
BR
Michael
03-26-2018 06:05 AM
Hi!
Can apply a filter to the command “show risdb query phone”, that only shows me the unregistered phones?
Which command should I use?
Thanks !!
03-26-2018 06:54 AM
03-26-2018 07:55 AM
03-26-2018 07:40 PM
03-26-2018 08:30 PM - edited 03-26-2018 08:33 PM
The doc talks about the same info which Mohammed had already provided, but it's still a good read.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118307-probsol-cucm-00.pdf
Please rate if you find this helpful.
Aeby
