CUCM SQL - Phone Registeration Status
robertphillips2
All,
Are the individual phone registration status stored anywhere in the CUCM DB that can be queried via SQL? If so, can someone share which table and value?
I know there are multiple alternate ways of getting this information, but I am working on some custom SQL queries for CUCM that I would like to add device registration status to.
Rob
Anthony Holloway
Depending on how you are accessing the SQL query (CLI, AXL, Other) you could run the following command on the CLI (per server):
show risdb query phone
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
11 Replies 11
Jaime Valencia
No, that information is not stored in any table in the DB.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Gordon Ross
Level 9
Level 9
This information is only available via the RIS API set. It's not stored in the SQL database.
GTG
Please rate all helpful posts.
Anthony Holloway
Anthony Holloway
is it possible to get with this report "show risdb query phone" also these informations?
- directory number
- partition
- pickup group
BR
Michael
No, because that command gets the info only from risdb process, not from any table from CUCM.
java
java
OK thanks.
Is there any other SQL command to use to get these informations:
- all directory numbers
- partition
- description
- Associated Devices (phone or device profile)
- Call Pickup Group
BR
Michael
Hi!
Can apply a filter to the command “show risdb query phone”, that only shows me the unregistered phones?
Which command should I use?
Thanks !!
You can view this nicely from RTMT and filter as needed. Go to Voice/Video
> Device > Device Search > Go to Device Search > Phone
Thanks for the info!
The problem that I've is that with the RTMT I can´t export this information to an Excel or Acces.
Is there any tool to do this?
Thnaks!
Paul/Pablo
In this case export the entire table from risdb command and use excel
filter to get the data you want (filter based on status)
The doc talks about the same info which Mohammed had already provided, but it's still a good read.
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118307-probsol-cucm-00.pdf
Please rate if you find this helpful.
Aeby
Aeby
