CUCM SQL query
karthikvish2000
Hello all,
I am wondering if there is an SQL query that would return "User ID" and corresponding "Primary Extension" for a user.
I have configured "Primary extension" for all users in the cluster and I wish to extract this information using AXL for import into a 3rd party application for a custom solution (details not required).
Can somebody please help with this?
Karthik
Brett Fritzsch
Karthik,
This query will match the EndUser ID to the primary extension that is configured on the end user page and list out the UserID and Extension.
run sql select e.userid, n.dnorpattern from enduser as e, numplan as n, endusernumplanmap as x where (e.pkid = x.fkenduser and x.fknumplan = n.pkid)
Hope this helps!
-Brett Fritzsch
10 Replies 10
Brett Fritzsch
Karthik,
Hope this helps!
-Brett Fritzsch
Hi Bret,
Will this query works with Cisco CUCM 8.5 also?
And also, I could not able to understand this query correctly. Do we need to directly run "
run sql select e.userid, n.dnorpattern"?
Thanks for sharing this valuable info.
Regards...
-Ashok.
With best regards...
Ashok
Ashok,
Yes this will work on 8.5.  In regards to the query just copy and paste what I have below:
You should get an output like the following:
userid   dnorpattern
5659     5659
5658     5658
test     69211
5657     5657
TestUser 8006
Hope this helps!
-Brett Fritzsch
Thanks a lot, Brett.
It's really great help.
Regards...
-Ashok.
Ashok
Excellent.
Thanks Brett. This is exactly what I am after.
Thanks for your help. Really appriciate it.
Hi Brett.  If you are still around can you tell me how to output this query to a file?
You can simply use a program like putty to SSH, and configure it to capture all the output of the session to a text file.
java
if this helps, please rate
Hi again, my query is not returning everything because I do not see my own userid  sdh7820.
Any idea?
I figured it out. You must have the Directory Number Association  / Primary Extension in the End User Configuration. So this may or maynot be completed for all Users. Any other suggestions.  What I really want to do is clean up my CUCM.  As I close a site I want to be able to clean everything up and delete the device and everthing associated with (CSS, DP, Location...) I want to get the End User and the Default Profile associated with a DN?
Sandy,
If you add e.telephoneNumber to the select =>
select e.userid, n.dnorpattern, e.telephoneNumber from enduser as e ...
You should see both of them.
Br,
Geert
