10-18-2011 02:25 AM - edited 03-16-2019 07:34 AM
Hello all,
I am wondering if there is an SQL query that would return "User ID" and corresponding "Primary Extension" for a user.
I have configured "Primary extension" for all users in the cluster and I wish to extract this information using AXL for import into a 3rd party application for a custom solution (details not required).
Can somebody please help with this?
Karthik
Solved! Go to Solution.
10-18-2011 05:48 AM
Karthik,
This query will match the EndUser ID to the primary extension that is configured on the end user page and list out the UserID and Extension.
run sql select e.userid, n.dnorpattern from enduser as e, numplan as n, endusernumplanmap as x where (e.pkid = x.fkenduser and x.fknumplan = n.pkid)
Hope this helps!
-Brett Fritzsch
10-18-2011 05:48 AM
Karthik,
Hope this helps!
-Brett Fritzsch
10-18-2011 06:37 AM
Hi Bret,
Will this query works with Cisco CUCM 8.5 also?
And also, I could not able to understand this query correctly. Do we need to directly run "
run sql select e.userid, n.dnorpattern"?
Thanks for sharing this valuable info.
Regards...
-Ashok.
10-18-2011 06:41 AM
Ashok,
Yes this will work on 8.5. In regards to the query just copy and paste what I have below:
You should get an output like the following:
userid dnorpattern
5659 5659
5658 5658
test 69211
5657 5657
TestUser 8006
Hope this helps!
-Brett Fritzsch
10-18-2011 10:43 PM
Thanks a lot, Brett.
It's really great help.
Regards...
-Ashok.
10-24-2011 12:49 AM
Excellent.
Thanks Brett. This is exactly what I am after.
Thanks for your help. Really appriciate it.
11-07-2014 07:17 AM
Hi Brett. If you are still around can you tell me how to output this query to a file?
11-07-2014 07:38 AM
You can simply use a program like putty to SSH, and configure it to capture all the output of the session to a text file.
11-07-2014 08:46 AM
11-07-2014 01:04 PM
I figured it out. You must have the Directory Number Association / Primary Extension in the End User Configuration. So this may or maynot be completed for all Users. Any other suggestions. What I really want to do is clean up my CUCM. As I close a site I want to be able to clean everything up and delete the device and everthing associated with (CSS, DP, Location...) I want to get the End User and the Default Profile associated with a DN?
03-20-2016 01:15 AM
Sandy,
If you add e.telephoneNumber to the select =>
select e.userid, n.dnorpattern, e.telephoneNumber from enduser as e ...
You should see both of them.
Br,
Geert
