CUCM sql question
How can I run several repeating commands in CUCM sql ? Can I just copy the list of command and paste , like i do with cisco router IOS ? Or is there way to run TCL script ?
Thank you
Don't reinvent the wheel. Check the 'offiical' python script examples:
https://www.vandyke.com/support/securecrt/python_examples.html
The Send.Data.py example looks like what you're after.
7 Replies 7
balaji.bandi
I used some time back..CUCM using the Cisco AXL API you can use that for scripting.
BB
will.alvord
Level 5
Level 5
It's either AXL or you can script SecureCRT or whatever terminal client you're using or a whole lot of copy/pasting.
what are you looking, Hope if i understand correctly you looking to automate and execute the SQL right ?
and store the results either email or file. ( success or failure).
BB
I have to turn off display name on about 200 cisco codecs. I have made sql command and tested successfully but it's just one line and I'd need to copy paste 200 times :D . U mentioned securecrt , I have it , how to automate with it or  script on it? , sorry guys im not good with AXL and think is freaking complicated as every cisco stuff.
Thank you
Looks like I found way to do in SecureCRT, there is embedded functionality u can record script and save as vbs or python and then edit and run it. Its very good for  people like me not so expereinced with scripting :) .
I ll try to solve my problem and send SQL command to CUCM and see how it will work . I just need to recall  now how to make pause and wait  response from sql serevr in the python script before to send next line.
Yeeees, u r right, Thank you bro :)
