CUCM - Time of Day Routing - Exchange Auto Attendant
Robert Stack
Greetings,
Noob here. I am looking to setup CUCM with Exchange 2013 UM to forward external calls from the Auto Attendant for certain extensions back to Exchange to leave a voice message, only at certain times of the day. For example if a external caller chooses Bobby Smith from the auto attendant at 9am, it will go to his voice mail but if it is 3pm, it rings the phone.
Can someone explain to me how this can be done in CUCM to create a time of day routing for external calls from the UM Auto Attendant to point them back to UM to a voice mail? We are currently on CUCM 7.1 but will be migrating to 9 soon.
Robb
Chris Deren
You should look for this on Exchange side, check if there is a concept of schedules there similar to Cisco Unity Connection, to do this on CUCM would be very inefficient and convoluted.
Chris
brmeade
Level 4
Level 4
You should just be able to do this by changing the schedule on the subscribers in Unity. And having separate transfer rules for Standard and Closed schedules.  Just have closed transfer rule send straight to Greeting instead.
Chris Deren
He does not have unity, he said he has exchange UM.
Thanks for the responses Chris and Brian. I will jump over to TechNet and see if anyone over there has any ideas. The documentation I have found so far on Exchange UM hasn't been very informational on setting it up. I am guessing that is either because it is limited in scope of what it can perform in comparison to Unity, or I have yet to find thorough configurations.
Cheers!
Robb
